Stan the Man
#1 Posted : Sunday, November 4, 2007 8:55:57 AM(UTC)
Stan the Man
Almost installed and before securing in space the door latch sticks and is hard to open. Will finishing the process, leveling and securing it to the counter help the latch problem or should I replace unit.:(
fixxit
#2 Posted : Sunday, November 4, 2007 10:52:34 AM(UTC)
fixxit
very possibly it will fix your problem. if the machine is in there all katywampus it will flex a bit and make it difficult to close and/or latch the door. good luck and post your results here
#3 Posted : Monday, November 5, 2007 1:00:36 AM(UTC)
I would pull out dishwasher slightly and if door closes ok but latch sticks I would spray some wd-40 on the latch and if adjustable with screws under the latch, I would adjust slightly out to reduce door closing pressure on the door seal.
If dishwasher is an older one I would try a little vaseline on the door gasket to soften it up.
maytag mde3757ayw heater installation (Dryer Repair)
by Guest 5/31/2023 7:31:33 AM(UTC)
Installation guide for Kenmore front load model 417.42052100 (Dryer Repair)
by rodmetal13 4/1/2023 2:36:17 AM(UTC)
Refrigerator Gasket installation error (Refrigerator & Freezer Repair)
by dbdata 3/23/2023 4:03:07 PM(UTC)
Maytag Dishwasher Not Entering Installation Cycle (Dishwasher Repair)
by Sparky9680 5/16/2022 9:37:56 AM(UTC)
Parts installation (Dishwasher Repair)
by jklikape@aol.com 6/23/2021 12:35:39 PM(UTC)
no wiring diagram for drain pump installation--HELP (Washer Repair)
by TanyaDA 3/17/2021 5:16:46 AM(UTC)
Need installation instruction sheet for Whirlpool kit 3968298 (Washer Repair)
by Nitro itch 11/4/2020 8:37:53 PM(UTC)
GE Zoneline (AZ41E12DABW1) remote thermostat installation (Heating, Ventilation, and Air Conditioning (HVAC))
by jasonhunt007 5/27/2020 6:57:33 AM(UTC)
GE range JB645DK4BB new installation, control panel is blank (Oven Repair (including Ranges and Cooktops))
by jpmriley 12/27/2019 11:13:14 AM(UTC)
Dryer Motor clamp / clip installation technique ? (Dryer Repair)
by diydude99 12/9/2017 12:07:41 PM(UTC)
LG Dishwasher Installation Problem (Dishwasher Repair)
by bsimp220 4/19/2016 9:45:52 AM(UTC)
New Maytag Dishwasher -- Installation of drain line? (Dishwasher Repair)
by jim.thornton 12/13/2015 3:39:31 PM(UTC)
Manifold Bracket Installation (Dishwasher Repair)
by Dobermann 12/6/2014 10:03:05 PM(UTC)
Kenmore Elite Dishwasher diverter installation (Dishwasher Repair)
by fasta6 11/13/2014 6:26:52 AM(UTC)
Oven door installation (Oven Repair (including Ranges and Cooktops))
by macmom 9/26/2014 6:09:08 PM(UTC)
