diceboy15
#1 Posted : Wednesday, September 14, 2011 12:52:00 PM(UTC)
diceboy15
The light is out on the control board for the temp setting for the refrigerator--the one for the freezer is still on. When I press the refrigerator setting button, it beeps but no light shows. Will the temp setting still work properly? Is it just a matter of not seeing the little green light to tell me what number it's set on or can this actually affect the cooling system?. thanks so much for any help
#2 Posted : Thursday, September 15, 2011 1:38:42 AM(UTC)
[COLOR="DarkRed"]Will the temp setting still work properly? Is it just a matter of not seeing the little green light to tell me what number it's set on or can this actually affect the cooling system?.[/COLOR]
It could be either one of the above.
Get a fridge thermometer and measure the temperature in the fresh food section on a middle shelf. It should be around 40 degrees F.
Then raise it or lower it to see if the actual control works. Give it at least 8 hours before rechecking it.
That will tell you if the control still works.
Have you tried unplugging the unit for 5 minutes or so to see if it will reset?
diceboy15
#3 Posted : Friday, September 16, 2011 10:04:02 AM(UTC)
diceboy15
Thanks for the response.
Unplugging hasnt helped. I have a thermometer in the fridge, and it wont get off 43-44 deg. I pressed the fridge temp control button and rechecked the next day, still same temp. There is some frost on the back panel in the freezer-I defrosted the coils and less than 24 hrs later, the frost was on the panel again. Does the board affect the defrost system too? I was hoping that it was just a burnt bulb since the little green indicator light was out-it still beeps when u press the button to adjust the temp, but the temp doesnt change. thanks again
#4 Posted : Saturday, September 17, 2011 4:33:53 AM(UTC)
Replacement parts for WHIRLPOOL KSRP25FSSS01 REFRIGERATOR | AppliancePartsPros.com
See the attachment for the tech sheet
Yes the control board also controls the defrost.
File Attachment(s):
KSRP25.pdf (679kb) downloaded 4 time(s).
diceboy15
#5 Posted : Saturday, September 17, 2011 9:41:29 AM(UTC)
diceboy15
So its possible that the board works well enough to keep the fridge temp at 43 deg, but not well enough to get it lower? Thanks
#6 Posted : Sunday, September 18, 2011 2:04:42 AM(UTC)
Yes it is possible.
diceboy15
#7 Posted : Sunday, September 18, 2011 4:50:43 AM(UTC)
diceboy15
Yes it is possible.
thanks for the help denman--will try changing out the board
anything out of the ordinary i need to now when changing it, or is it a simple remove and replace? thanks
Guest (4)
Kitchen aid control board (Dishwasher Repair)
by abtrman 3/10/2010 9:41:49 AM(UTC)
Kitchen Aid Control Board Replacement Help (Microwave Repair)
by tjgx100 12/5/2008 2:04:52 PM(UTC)
