djupin
#1 Posted : Friday, December 19, 2008 9:40:16 AM(UTC)
djupin
My Whirlpool double oven display is blank. Pressing most of the buttons gives a short long short short short beep sequence. Is there anyway to reset this or does one of the modules need to be replaced?
If it a module fault would it be the control panel or the clock control module? I suspect the control module.
Thanks.
Dave Jupin
libertyappl
#2 Posted : Friday, December 19, 2008 10:15:10 AM(UTC)
libertyappl
I would check the power supply first, then the thermal fuse on the back and the control board.
Here's your breakdown Model GBD307PDS09
Nat
djupin
#3 Posted : Friday, December 19, 2008 5:19:59 PM(UTC)
djupin
I checked the transformer with the power off and got 58.7 ohms on the primary and 2.6 ohms on the secondary. I think that it is OK.
I also checked the thermal fuse on P24 and it seems OK.
The top of the clock control board seems to have some discoloration. I am pretty certain at this point that the board is bad.
I only hope that the display board is also not bad.
Dave Jupin
libertyappl
#4 Posted : Saturday, December 20, 2008 9:53:34 AM(UTC)
libertyappl
Sounds like the control board is the problem.
nat
djupin
#5 Posted : Wednesday, December 31, 2008 5:21:12 AM(UTC)
djupin
I was able to fix the oven by replacing the control board. Several places that I checked did not have the board in stock - seems like maybe there are a lot of failures of this board.
I was able to get the board from Tribles which is a local appliance parts store. They have a few locations and overnighted it to me from Richmond.
I replaced it Christmas eve and we were able to use it on Christmas.
Dave Jupin
libertyappl
#6 Posted : Wednesday, December 31, 2008 5:34:41 AM(UTC)
libertyappl
Glad you were able to get it fixed!!
Nat
Whirlpool oven problems... (Oven Repair (including Ranges and Cooktops))
by chappy801 5/31/2012 6:42:47 PM(UTC)
Whirlpool oven problems with heating. (Microwave Repair)
by double d 7/24/2009 8:15:54 AM(UTC)
intermittent Whirlpool oven problem (Oven Repair (including Ranges and Cooktops))
by jackchaos 2/16/2009 8:31:04 AM(UTC)
by regent 3/27/2008 5:29:03 AM(UTC)
