SDG
#1 Posted : Monday, December 29, 2008 2:22:06 PM(UTC)
SDG
I am replacing the transmission brake assembly on this GE Profile washer. I have the tub/drive assembly removed from the machine, but cannot remove the agitator to allow me to remove the spin basket from the tub.
Any suggestions? When I remove the cap from the fabric softener there is a semi-transparent cap below it that I cannot seem to move and am trying to avoid breaking.
Drags1998
#2 Posted : Monday, December 29, 2008 4:38:56 PM(UTC)
Drags1998
You don't need to remove that cover, The agitator just pulls off, (no bolts) The special tub wrench is what your gonna need, It fits the BIG NUT under the white plastic agitator drive block.
#3 Posted : Tuesday, December 30, 2008 2:46:57 AM(UTC)
Good luck with that tub nut, you may want to post this removal as a separate problem if you have trouble, I believe it is a left hand thread.
SDG
#4 Posted : Tuesday, December 30, 2008 6:57:39 AM(UTC)
SDG
Thanks, that worked.. Got the tub nut with a 8" pipe wrench.... All back together and running fine.
SDG
#5 Posted : Tuesday, December 30, 2008 6:58:12 AM(UTC)
SDG
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
OEM or Aftermarket Replacement Bake Element? (Oven Repair (including Ranges and Cooktops))
by lbb78 4/18/2024 10:05:55 AM(UTC)
replacement for discontinued GE convection fan motor? (Oven Repair (including Ranges and Cooktops))
by evofxdwg 4/11/2024 11:12:12 AM(UTC)
Replace W10121140 on a KSSC42QVS06 (Refrigerator & Freezer Repair)
by milehigh786 3/26/2024 5:45:30 AM(UTC)
Kenmore/Whirlpool GB22DKXJW00 - evap fan replacement no ground (Refrigerator & Freezer Repair)
by DIY2024 3/24/2024 1:07:07 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Bosch SHP88PW55N water softener issue / replacement (Dishwasher Repair)
by jgoode0417 3/13/2024 8:03:16 AM(UTC)
Cabrio bearing replacement (Washer Repair)
by Guest 2/26/2024 4:58:10 AM(UTC)
GE outer tub and seal replacement issue (Washer Repair)
by Bobby0600 2/14/2024 9:06:57 PM(UTC)
KERS206XSS1 thermostat replacement part (Oven Repair (including Ranges and Cooktops))
by Guest 1/23/2024 3:59:52 PM(UTC)
Replaced valve quad still drips (Washer Repair)
by jbell1033 1/20/2024 1:30:49 PM(UTC)
Confused!!! Trying to wire up a replacement motor for Kenmore 110.86983800 (Dryer Repair)
by Guest 1/17/2024 10:02:08 AM(UTC)
GDF650SSJ0SS - replaced door latch, control board - what's next? (Dishwasher Repair)
by Guest 12/11/2023 11:31:42 PM(UTC)
