Buffy201
#1 Posted : Thursday, December 25, 2008 7:07:04 PM(UTC)
Buffy201
Kenmore 70 series dryer wont heat. What can I do ?
#2 Posted : Friday, December 26, 2008 11:55:10 AM(UTC)
You can find the complete troubleshooting instructions in one of our previous posts: http://forum.appliancepartspros...3-no-heat-gas-dryer.html
- The part number for the thermal fuse (#39 on the break down diagram) is AP3132867
- The part number for the cycling thermostat (#41 on the break down diagram) is AP3131939
It is recommended by the manufacturer to replace the cycling thermostat together with the thermal fuse if it's open.
- The part number for the igniter (#4 on the break down diagram) is AP3094138
- The part number for the flame sensor (#9 on the break down diagram) is AP2910747
- The part number for the gas valve coil kit (#13 & 14 on the break down diagram) is AP3094251
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
