I replaced the Broil Element and the Sensor in this oven. After replacing both items the the system would not regulate the heat. The Broil element would stay hot. I then shut power off to the oven at the breaker for about 10 minutes and tried again. After the oven went through the preheat I received Error code E2 F3. This shows bad sensor, just replaced sensor, what gives?? Am I missing a step in the process??:confused:
Check you connections to the sensor.
Nat
Is there a way to test the sensor? I checked the connection and it all seems to be good.
You can test it with an ohm meter to see if it has continuity.
Nat
Is there a range in the reading that I should be looking for?
It should be listed on the tech sheet, usually inside the control panel.
Nat
I am getting 1.088K on both the old sensor as well as the new one. My problem must be somewhere else??
THIS FORUM IS DEAD!!!!!!! |
Thanks, that helps except for now the door is locked and it is closed and I cant get it open. This is great for baking at Christmas...
