2 Pages12>
garylrodgers
#1 Posted : Wednesday, December 24, 2008 7:55:20 AM(UTC)
garylrodgers
I replaced the Broil Element and the Sensor in this oven. After replacing both items the the system would not regulate the heat. The Broil element would stay hot. I then shut power off to the oven at the breaker for about 10 minutes and tried again. After the oven went through the preheat I received Error code E2 F3. This shows bad sensor, just replaced sensor, what gives?? Am I missing a step in the process??:confused:
libertyappl
#2 Posted : Wednesday, December 24, 2008 8:35:01 AM(UTC)
libertyappl
Check you connections to the sensor.
Nat
garylrodgers
#3 Posted : Wednesday, December 24, 2008 10:40:12 AM(UTC)
garylrodgers
Is there a way to test the sensor? I checked the connection and it all seems to be good.
libertyappl
#4 Posted : Wednesday, December 24, 2008 10:48:21 AM(UTC)
libertyappl
You can test it with an ohm meter to see if it has continuity.
Nat
garylrodgers
#5 Posted : Wednesday, December 24, 2008 11:01:34 AM(UTC)
garylrodgers
Is there a range in the reading that I should be looking for?
libertyappl
#6 Posted : Wednesday, December 24, 2008 11:04:55 AM(UTC)
libertyappl
It should be listed on the tech sheet, usually inside the control panel.
Nat
garylrodgers
#7 Posted : Wednesday, December 24, 2008 12:20:44 PM(UTC)
garylrodgers
I am getting 1.088K on both the old sensor as well as the new one. My problem must be somewhere else??
#8 Posted : Wednesday, December 24, 2008 1:43:52 PM(UTC)
In case you do not have it here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208301758.pdf
garylrodgers
#9 Posted : Wednesday, December 24, 2008 3:02:44 PM(UTC)
garylrodgers
Thanks, that helps except for now the door is locked and it is closed and I cant get it open. This is great for baking at Christmas...
garylrodgers
#10 Posted : Sunday, December 28, 2008 5:59:19 PM(UTC)
garylrodgers
2 Pages12>
