Greta Elliott
#1 Posted : Friday, November 2, 2007 8:32:24 AM(UTC)
Greta Elliott
I have a Montgomery Ward refrigerator and the defrost cycle is not working. I am trying to find the location of the defrost timer to fix or replace. However, I cannot find the location of it. Can you help? thanks
#2 Posted : Friday, November 2, 2007 9:02:05 AM(UTC)
Hi Greta
The model number you posted is incomplete or incorrect. In order to provide the most accurate advise I need the complete model number of your fridge.
zzrobert
#3 Posted : Saturday, November 3, 2007 11:58:18 PM(UTC)
zzrobert
Greta go here for how to fix your fridge:
Refrigerator Defrost Cycle Diagnostics
Go here for the cheapest and most complete parts:
http://www.***********************.com/default.aspx
I just fixed mine and I put in the thermostat and timer and what it needed was the defrost heaters. It isn't hard. You need to take off the panel in the freezer behind the shelves. The first link has the pictures. To see the defrost heaters there are two metal panels you need to take off and look at the heaters.
Guest (4)
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
by Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
