sue1759
#1 Posted : Friday, November 2, 2007 8:17:06 AM(UTC)
sue1759
My dryer just stooped heating up enough to dry clothes. The start button stopped working and so I just have to turn the dial for any cycle and it goes on but the cycles run continuously without completely drying. Silver heat shield inside gets hot but I don't feel air blowing. It spins just fine. This is just over 18 months old any suggestions?
#2 Posted : Friday, November 2, 2007 9:11:18 AM(UTC)
Hi sue1759
The first thing I would do is check the continuity across the start switch terminals. It should be normally open and if it's closed then replace the start switch.
How did you check the air flow? Did you dis connect the vent hose from the dryer?
- The pat number for the new start switch AP2042901
- Here are the break down diagrams for the GE dryer Model DX4500GA1WW
Good luck.
sue1759
#3 Posted : Friday, November 2, 2007 12:12:27 PM(UTC)
sue1759
ok it's spinning and the plate is warm but not getting hot--only when it wants to
#4 Posted : Friday, November 2, 2007 12:31:24 PM(UTC)
I really need you to answer on my questions in order to help you.
sue1759
#5 Posted : Friday, November 2, 2007 1:07:28 PM(UTC)
sue1759
I am able to turn it on with the door open since I had to change the way the door opens. That is how I know that no air is blowing in but it is coming out of the vent.
#6 Posted : Friday, November 2, 2007 4:09:08 PM(UTC)
If the dryer can be turned on with just the timer and without the start switch, then the start switch is probably bad and has to be replaced.
If the dryer is working with the door open this is a major safety issue and the door switch has to be replaced or the door needs an adjustment.
If the dryer heats up but not drying properly, most likely the problem is a clogged vent or the blower inside the dryer. Disconnect the vent hose from the back of the dryer and run a load with the hose being disconnected. If you see a difference, then the vent has to cleaned.
Guest (4)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
LG dryer not drying clothes (Dryer Repair)
by DGRA0005 7/6/2020 5:42:51 PM(UTC)
Whirlpool wed4800bq1 dryer not drying very good (Dryer Repair)
by t3i 3/19/2019 3:10:19 PM(UTC)
Dryer not drying (Dryer Repair)
by Scotty dog 12/3/2017 10:46:30 AM(UTC)
Dryer not Drying Clothes (Dryer Repair)
by Epfever1 12/1/2017 9:44:44 AM(UTC)
dryer not drying and water in drum (Dryer Repair)
by sonjawainwright 8/23/2017 8:07:12 AM(UTC)
Matag Dryer not drying in Intellidry Mode (Dryer Repair)
by themooser98 8/23/2017 5:43:28 AM(UTC)
maytag centennial electric dryer not drying/heating anymore (Dryer Repair)
by lloyd raymond martin 6/7/2017 5:34:16 PM(UTC)
Maytag Centennial Dryer not drying completely. (Dryer Repair)
by bryanakers 10/10/2016 5:42:01 AM(UTC)
My Dryer not drying (Dryer Repair)
by anikabrown 3/29/2016 3:57:03 AM(UTC)
Dryer not Drying (Dryer Repair)
by BraxLimbo 11/12/2015 11:08:58 PM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Samsung dryer not drying/get hot (Dryer Repair)
by Mommydearest819 5/30/2015 3:31:39 AM(UTC)
LG Tromm Dryer not drying (Dryer Repair)
by earcaesar 3/26/2015 5:50:26 PM(UTC)
