ETGolfer
#1 Posted : Monday, August 29, 2011 9:49:25 AM(UTC)
ETGolfer
Ice dispenser arm does not move, no sound after paddle depressed. I have already ordered and received a replacement motor from here, but now I need to know how to access the motor area. How do I remove the panel(s) to access the motor? Please advise!
#2 Posted : Monday, August 29, 2011 2:45:58 PM(UTC)
Does the water dispenser work?
Did you hear a beep when you depressed the ice release paddle?
Which motor did you order?
Did you test it or you are just guessing?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSCS25FTSS00 REFRIGERATOR | AppliancePartsPros.com
ETGolfer
#3 Posted : Monday, August 29, 2011 3:10:52 PM(UTC)
ETGolfer
Thanks Gene for the reply. Yes the water works, neither the water or ice paddle beep when depressed. I just thought it was probably the motor so I ordered the only one shown on the schematic.
#4 Posted : Monday, August 29, 2011 4:12:53 PM(UTC)
I'm assuming you are talking about the ice door motor.
The instructions are attached to the reply.
File Attachment(s):
Ice door motor removal.doc (1,027kb) downloaded 18 time(s).
Ice door motor test.doc (65kb) downloaded 13 time(s).
ETGolfer
#5 Posted : Tuesday, August 30, 2011 5:38:47 AM(UTC)
ETGolfer
Thanks Gene, this will get me into the motors. Do you also have a "testing sequence" for the IDI motor? Also, if these motors are OK, what else should I check.
#6 Posted : Tuesday, August 30, 2011 3:09:27 PM(UTC)
You are welcome. These instructions are attached to this reply.
File Attachment(s):
In-Door-Ice motor removal and testing.doc (1,008kb) downloaded 17 time(s).
Testing an ice dispenser motor- Kitchenaid/Whirlpool (Refrigerator & Freezer Repair)
by viabill 5/8/2019 5:59:09 PM(UTC)
burning up Whirlpool ice dispenser motors (Refrigerator & Freezer Repair)
by dicktrickle88 6/3/2015 12:05:20 PM(UTC)
Ice dispenser motor wire schematic (Refrigerator & Freezer Repair)
by flymom 7/27/2014 11:14:15 AM(UTC)
Can' t unscrew auger from ice dispenser motor shaft (Refrigerator & Freezer Repair)
by Mtwoodson 8/6/2013 8:52:22 PM(UTC)
ice dispenser motor replaced and still doesnt work (Refrigerator & Freezer Repair)
by bryan9097 7/18/2012 9:30:50 AM(UTC)
ice dispenser motor won't turn off (Refrigerator & Freezer Repair)
by Warren R 5/16/2012 10:08:55 AM(UTC)
New Ice dispenser Motor (Refrigerator & Freezer Repair)
by jurgyman 2/16/2012 5:46:53 AM(UTC)
Ice dispenser motor (Refrigerator & Freezer Repair)
by ralph werner 1/30/2012 4:44:59 PM(UTC)
Ice dispenser motor replacement (in door) (Refrigerator & Freezer Repair)
by lhawthorne3 1/19/2012 3:40:23 PM(UTC)
How To Change Ice Dispenser Motor (Refrigerator & Freezer Repair)
by ratchet52 11/29/2011 2:30:52 PM(UTC)
ice dispenser motor turning wrong way (Refrigerator & Freezer Repair)
by rogerstreetman 10/12/2011 10:14:42 AM(UTC)
Ice Dispenser Motor will not turn (Refrigerator & Freezer Repair)
by tcounts 9/12/2011 8:37:02 AM(UTC)
Ice dispenser motor - no sound (Refrigerator & Freezer Repair)
by dkeeb 12/15/2010 3:12:25 PM(UTC)
Ice dispenser motor keeps freezing up (Refrigerator & Freezer Repair)
by TJLight 8/23/2010 9:57:15 AM(UTC)
how to replace ice dispenser motor (Refrigerator & Freezer Repair)
by 1954bigd 1/12/2009 2:42:33 PM(UTC)
