erniej
#1 Posted : Wednesday, August 24, 2011 9:04:04 AM(UTC)
erniej
My GE Profile side by side refrigerator will not cool (both the freezer and refrigerator). When I removed the back cover I noticed that the compressor will not turn on. I disconnected the refrigerator for 12 hours, when I reconnected the unit I heard a very quick click but the same occurs (the compressor will not turn on).
#2 Posted : Thursday, August 25, 2011 1:20:44 AM(UTC)
Pull out the motherboard in the back and check for bad solder joints by the big power relay, re-solder if needed.
If ok, remove the 3 pin power connector and place a wire jumper between the mating pins as labeled line and comp on the board. Plug fridg in, if the compressor runs, replace the motherboard AP4436216
refrigerator and freezer not cooling (Refrigerator & Freezer Repair)
by robertch1 10/13/2014 4:03:59 PM(UTC)
Refrigerator and Freezer not cooling (Refrigerator & Freezer Repair)
by RichF 7/13/2014 3:03:42 PM(UTC)
by marmitage 2/5/2014 5:03:44 PM(UTC)
Refrigerator and freezer not cooling (Refrigerator & Freezer Repair)
by denada777 1/23/2014 3:32:07 PM(UTC)
by JHubb 8/25/2013 11:00:04 AM(UTC)
by slick154 3/20/2013 11:28:42 AM(UTC)
Amana Refrigerator and Freezer not cooling (Refrigerator & Freezer Repair)
by gabyrink 3/17/2013 5:10:31 PM(UTC)
by pbburkeen 7/5/2012 4:23:47 PM(UTC)
Refrigerator and freezer not cooling after lightning storm (Refrigerator & Freezer Repair)
by Jcrooker 6/17/2012 1:56:56 PM(UTC)
refrigerator and freezer not cooling properly (Refrigerator & Freezer Repair)
by Gman60 4/13/2011 6:18:17 AM(UTC)
by bboud 12/9/2010 9:51:56 AM(UTC)
Magic Chef Refrigerator and Freezer not cooling (Refrigerator & Freezer Repair)
by telephoneman 7/15/2010 11:57:22 AM(UTC)
by karinarao 5/7/2010 2:15:33 PM(UTC)
by Esther Iwunna 12/14/2009 9:26:01 PM(UTC)
Refrigerator and freezer not cooling. (Refrigerator & Freezer Repair)
by smgodoy24 10/7/2009 5:11:01 AM(UTC)
