riccole
#1 Posted : Friday, December 19, 2008 2:37:25 PM(UTC)
riccole
Upper oven will not heat up. All lights and dials work, but no heat
riccole
#2 Posted : Friday, December 19, 2008 2:43:48 PM(UTC)
riccole
Originally Posted by: riccole Go to Quoted Post
Upper oven will not heat up. All lights and dials work, but no heat. Is it the thermal disc and how do I replace it?quote]
#3 Posted : Saturday, December 20, 2008 2:19:55 PM(UTC)
Usually there is a resettable thermodisc behind the control panel in all such ovens but it's not shown on the diagram for this model and I could not find the wiring diagram for this particular model.
Here are the break down diagrams for the Kitchen Aid oven Model KEBS277WBL0
ssbbidask
#4 Posted : Thursday, August 28, 2014 4:35:48 AM(UTC)
ssbbidask
Man
United States
Gene, I too have an issue very much like this one. You had helped me a couple years ago when this oven locked up during it's first cleaning. In that case the oven blew the thermostat, the line fuse to the board and the board! Ouch. Now that these repairs were done for about a year, the upper oven has now just stopped heating though I am able to use the lower over without a problem.
The control board activates the oven and shows it is heating just never heats up at all. What is this re-settable thermodisc you discuss in this post? Is it involved in the wiring of my unit? IF not what other tips can you give me to troubleshoot this matter?
Thanks, Tom
P.S. the diagram on the previous post does not come up so that didn't offer me any help.
Guest (5)
KitchenAid double oven - broiler working, oven won't warm (Oven Repair (including Ranges and Cooktops))
by jcz24 11/28/2022 5:53:17 AM(UTC)
KitchenAid Double Oven Won't Hold Temperature Set at and light won't go off (Oven Repair (including Ranges and Cooktops))
by Guest 5/13/2021 3:39:20 AM(UTC)
KitchenAid Double Oven Gas Range Top Oven Will Not Bake (Will Broil and Light works) (Oven Repair (including Ranges and Cooktops))
by jill35 11/14/2019 7:41:05 AM(UTC)
Kitchenaid Double Oven Not Heating to Correct Temp (Oven Repair (including Ranges and Cooktops))
by JustDoItAgain 1/11/2016 4:25:56 PM(UTC)
Kitchenaid Double Oven Upper Oven very long Preheat (Oven Repair (including Ranges and Cooktops))
by kthygesen 12/16/2013 6:45:37 PM(UTC)
by kthygesen 12/16/2013 6:42:57 PM(UTC)
Bottom of KitchenAid Double Oven not heating after running self-clean (Oven Repair (including Ranges and Cooktops))
by AllyCleveland 11/19/2013 1:46:47 PM(UTC)
Kitchenaid Double Oven Lights Not Working (Oven Repair (including Ranges and Cooktops))
by curlw 5/7/2013 9:16:29 AM(UTC)
Kitchenaid Double oven quit working after running a cleaning cycle (Oven Repair (including Ranges and Cooktops))
by sharon1 8/10/2012 11:52:21 AM(UTC)
KitchenAid Double Oven ECR (Oven Repair (including Ranges and Cooktops))
by honsinsr 5/31/2011 5:07:57 PM(UTC)
Kitchenaid Double Oven -- Error Code F2 - E1 -- How to Repair (Oven Repair (including Ranges and Cooktops))
by sdbmb 11/18/2009 4:20:01 PM(UTC)
KitchenAid Double Oven (Oven Repair (including Ranges and Cooktops))
by david.dickerson@solvay.co 3/19/2009 5:37:37 AM(UTC)
