david.dickerson@solvay.co
#1 Posted : Thursday, March 19, 2009 5:37:37 AM(UTC)
My Kitchenaid Double oven went totally dead last night during the self-clean cycle. About 2 hours into the cycle the display shut down and the top oven door is still locked and cannot be opened. I reset the braker and nothing worked. Any ideas???
TechnicianBrian
#2 Posted : Thursday, March 19, 2009 10:53:38 AM(UTC)
TechnicianBrian
Sounds like you have a thermal fuse that has failed. I wrote about this in my post Kitchenaid Double Oven no Heat after Self Clean that may answer your questions. Give it a read and see if you get your question answered.
KitchenAid double oven - broiler working, oven won't warm (Oven Repair (including Ranges and Cooktops))
by jcz24 11/28/2022 5:53:17 AM(UTC)
KitchenAid Double Oven Won't Hold Temperature Set at and light won't go off (Oven Repair (including Ranges and Cooktops))
by Guest 5/13/2021 3:39:20 AM(UTC)
KitchenAid Double Oven Gas Range Top Oven Will Not Bake (Will Broil and Light works) (Oven Repair (including Ranges and Cooktops))
by jill35 11/14/2019 7:41:05 AM(UTC)
Kitchenaid Double Oven Not Heating to Correct Temp (Oven Repair (including Ranges and Cooktops))
by JustDoItAgain 1/11/2016 4:25:56 PM(UTC)
Kitchenaid Double Oven Upper Oven very long Preheat (Oven Repair (including Ranges and Cooktops))
by kthygesen 12/16/2013 6:45:37 PM(UTC)
by kthygesen 12/16/2013 6:42:57 PM(UTC)
Bottom of KitchenAid Double Oven not heating after running self-clean (Oven Repair (including Ranges and Cooktops))
by AllyCleveland 11/19/2013 1:46:47 PM(UTC)
Kitchenaid Double Oven Lights Not Working (Oven Repair (including Ranges and Cooktops))
by curlw 5/7/2013 9:16:29 AM(UTC)
Kitchenaid Double oven quit working after running a cleaning cycle (Oven Repair (including Ranges and Cooktops))
by sharon1 8/10/2012 11:52:21 AM(UTC)
KitchenAid Double Oven ECR (Oven Repair (including Ranges and Cooktops))
by honsinsr 5/31/2011 5:07:57 PM(UTC)
Kitchenaid Double Oven -- Error Code F2 - E1 -- How to Repair (Oven Repair (including Ranges and Cooktops))
by sdbmb 11/18/2009 4:20:01 PM(UTC)
Kitchenaid double oven (Oven Repair (including Ranges and Cooktops))
by riccole 12/19/2008 2:37:25 PM(UTC)
