Upper oven will not heat up. All lights and dials work, but no heat
Originally Posted by: riccole  Upper oven will not heat up. All lights and dials work, but no heat. Is it the thermal disc and how do I replace it?quote]
Usually there is a resettable thermodisc behind the control panel in all such ovens but it's not shown on the diagram for this model and I could not find the wiring diagram for this particular model. Here are the break down diagrams for the Kitchen Aid oven Model KEBS277WBL0Gene.
Gene, I too have an issue very much like this one. You had helped me a couple years ago when this oven locked up during it's first cleaning. In that case the oven blew the thermostat, the line fuse to the board and the board! Ouch. Now that these repairs were done for about a year, the upper oven has now just stopped heating though I am able to use the lower over without a problem.
The control board activates the oven and shows it is heating just never heats up at all. What is this re-settable thermodisc you discuss in this post? Is it involved in the wiring of my unit? IF not what other tips can you give me to troubleshoot this matter?
Thanks, Tom
P.S. the diagram on the previous post does not come up so that didn't offer me any help.
