GylanAllen
#1 Posted : Friday, December 19, 2008 9:51:31 AM(UTC)
GylanAllen
I installed two new hinges on my oven door. Now the door will not remain open when it is wide open like it did with the old hinges, instead it now just snaps back shut; so you have to physically hold the door open to use the oven.
libertyappl
#2 Posted : Friday, December 19, 2008 10:16:15 AM(UTC)
libertyappl
The new springs are tighter, over time the door should stay open just like the old ones did.
nat
GylanAllen
#3 Posted : Friday, December 19, 2008 10:32:40 AM(UTC)
GylanAllen
I appreciate your responding to my concern about the hinges so quickly. I'm a little nervous because when we purchased the oven new the door stayed open and hinge springs didn't need to be exercised before they worked properly. Have you had actual experience where the hinges had to be exercised before the oven door would remain open?
libertyappl
#4 Posted : Friday, December 19, 2008 12:51:53 PM(UTC)
libertyappl
Whirlpool is making these a little heavier now, so hopefully they won't mess up again until you're ready to replace the range.
Nat
Where Online Can I Find Compatible DCS (Fisher & Paykel) Oven Door Hinges? (Refrigerator & Freezer Repair)
by WestLA 8/19/2019 10:57:44 AM(UTC)
No lockouts on Gas oven door hinges (Oven Repair (including Ranges and Cooktops))
by sendto 3/16/2018 8:49:42 AM(UTC)
Oven door hinges (Oven Repair (including Ranges and Cooktops))
by prcummings 1/20/2018 3:29:04 PM(UTC)
by llfraser 6/14/2013 7:19:47 AM(UTC)
by Ovenblues 4/12/2013 10:39:26 AM(UTC)
Whirlpool Oven Door Hinges Continuously Fail (Oven Repair (including Ranges and Cooktops))
by togamac 10/4/2012 8:50:36 AM(UTC)
Maytag oven door hinges replacement (Oven Repair (including Ranges and Cooktops))
by dennispandolfino 7/11/2012 2:25:00 PM(UTC)
by pastorapodaca 5/4/2011 9:25:06 AM(UTC)
Oven Door Hinges Replaced, Now Bad Again (Oven Repair (including Ranges and Cooktops))
by Mikeh14 2/10/2009 7:56:40 AM(UTC)
Replace oven door hinges (Oven Repair (including Ranges and Cooktops))
by charliesue 8/8/2008 4:05:57 PM(UTC)
Oven Door Hinges (Oven Repair (including Ranges and Cooktops))
by EEE 6/25/2008 6:59:06 PM(UTC)
