RAD
#1 Posted : Wednesday, December 17, 2008 2:23:03 PM(UTC)
RAD
Lower oven will not light, never gets above 100 degrees
upper oven works
kayakcrzy
#2 Posted : Thursday, December 18, 2008 5:27:44 AM(UTC)
kayakcrzy
It is most likely going to be the ignitor, that is what I would replace. Tom ApplianceEducator.com
Maytag Gemini - upper oven & broiler do not ignite (Oven Repair (including Ranges and Cooktops))
by cbrillow 5/14/2020 10:35:28 AM(UTC)
Maytag Gemini double oven electric (Oven Repair (including Ranges and Cooktops))
by mcelroy69 5/13/2020 10:22:20 AM(UTC)
Maytag Gemini-ovens randomly stop working power interrupt error (Oven Repair (including Ranges and Cooktops))
by romdos 9/2/2018 5:11:08 PM(UTC)
Maytag Gemini Front Right Dual Burner stays on High (Oven Repair (including Ranges and Cooktops))
by leday 2/19/2017 6:04:53 AM(UTC)
Maytag Gemini stove top not heating on all burners (Oven Repair (including Ranges and Cooktops))
by rebrake 7/26/2016 5:32:43 PM(UTC)
Maytag Gemini left rear burner stays on very low heat (Oven Repair (including Ranges and Cooktops))
by hh1126 5/12/2016 11:42:55 AM(UTC)
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 11/24/2015 7:23:04 AM(UTC)
Right Front Dual Element on Maytag Gemini (Oven Repair (including Ranges and Cooktops))
by danpreszler 11/21/2015 3:23:06 AM(UTC)
Maytag Gemini burner issue (Oven Repair (including Ranges and Cooktops))
by Krabby 11/18/2015 10:54:27 AM(UTC)
maytag gemini gas range wont light (Oven Repair (including Ranges and Cooktops))
by rtboten 9/25/2015 3:03:19 PM(UTC)
Maytag Gemini Double Oven Throws Codes After Sensor Replacements (Oven Repair (including Ranges and Cooktops))
by Gfiocca 11/18/2014 9:53:30 AM(UTC)
Maytag Gemini Double oven not working (Oven Repair (including Ranges and Cooktops))
by MTODD101 11/14/2014 1:01:34 PM(UTC)
Maytag Gemini Error Code F3-1 Not heating (Oven Repair (including Ranges and Cooktops))
by RichardMoody 11/3/2014 2:50:59 PM(UTC)
Maytag Gemini Dual Electric Oven (Oven Repair (including Ranges and Cooktops))
by wesjpeck 8/7/2014 4:38:19 AM(UTC)
Maytag Gemini F1-1 Code (Oven Repair (including Ranges and Cooktops))
by vcolella 5/30/2014 10:04:20 AM(UTC)
