Washer Will Agitate & Pump Water Out But Spins Only About 10 Seconds, In Any Cycle-wash-rinse-delecate
Originally Posted by: JMS1953  ...But Spins Only About 10 Seconds... Does the motor stop? If it does then remove the front panel and check if the motor is hot at this time. Post the results. Here are the break down diagrams for the GE washer Model WBSR1060T2AAGene.
Checked Motor.very Hot To The Touch!!!
Remove the belt and move the transmission pulley manually. If it moves in both ways then the motor is bad and has to be replaced.
