AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Top Load washer agitating & spinning problems
:confused: :confused: :confused: I started having agitating problems. Agitated slowly & sometimes even stopped on Normal/ fast cycle. Started washing smaller loads on gentle/ fast cycle & Seemed to be ok for awhile & then it stopped agitating all together. No problems with anything else so I hoped for an easy fix. I replaced the " drive bell & agitator" & it seemed to be ok. Agitator was actually working better then I've seen it for awhile. I tried this on all cycles before adding clothes. I finally did a small load & seemed to be working Great & suddenly I heard a Big Clanking Noise & immediately shut machine off. I Turned it back on & realized that now it had stopped spinning as well. I let all the water drain out & shut it off & wrong clothes out by hand & then I had help checking the belt & it seems to be fine. Any suggestions? At this point my brother-in-law took all the parts out of the machine so I dont know how I can check anything else but I will do My best. I loved this washer but dont want to put to much money into it Or keep replacing parts & still have problems. I have 4 grandkids & NOT having a way to wash has been very hard on all of us. Thanks!! :o ps not use to this thread & may not even find it again, so incase my email is citygirl_23_2000@yahoo.com
Originally Posted by: chedrick  :confused: :confused: :confused: I started having agitating problems. Agitated slowly & sometimes even stopped on Normal/ fast cycle. Started washing smaller loads on gentle/ fast cycle & Seemed to be ok for awhile & then it stopped agitating all together. No problems with anything else so I hoped for an easy fix. I replaced the " drive bell & agitator" & it seemed to be ok. Agitator was actually working better then I've seen it for awhile. I tried this on all cycles before adding clothes. I finally did a small load & seemed to be working Great & suddenly I heard a Big Clanking Noise & immediately shut machine off. I Turned it back on & realized that now it had stopped spinning as well. I let all the water drain out & shut it off & wrong clothes out by hand & then I had help checking the belt & it seems to be fine. Any suggestions? At this point my brother-in-law took all the parts out of the machine so I dont know how I can check anything else but I will do My best. I loved this washer but dont want to put to much money into it Or keep replacing parts & still have problems. I have 4 grandkids & NOT having a way to wash has been very hard on all of us. Thanks!! :o ps not use to this thread & may not even find it again, so incase my email is citygirl_23_2000@yahoo.com RE: Model # is WJSR4160D5WW
Groups: Expert
In order to help you, the machine must be put back together so you can do some tests while making observations that will help us diagnose your problem.
Eric
Washer Repair
