Modern Maid oven with two lower elements and one upper element. The Lower Outer blew and I got a replacement. Now neither lower elements are working. Where should I start looking? Is something fried possibly the oven control since the upper broil element works?
MODERN MAID model#DDU970 Serial#4983973 Bought 1984 An oven problem. If I set the oven for 250 the thermometer will register 300-350 and may flutuate. Am unable to set temp needed. Could this be the thermostat?? Clara
I have the exact problem and I think its a thermostat. Everything else works.
