momfixesit
#1 Posted : Wednesday, August 3, 2011 12:01:36 PM(UTC)
momfixesit
My GE Beverage center does not get cold. The fan in the back is running and the condenser is warm to the touch. When the unit was tuned on condensation would form on the inside back of the unit and then would freeze. I replaced the thermostat but it still doesn't get cold. Could you possibly tell me whats wrong?
#2 Posted : Thursday, August 4, 2011 12:11:29 AM(UTC)
What is the frost pattern on the evaporator?
momfixesit
#3 Posted : Thursday, August 4, 2011 2:41:43 AM(UTC)
momfixesit
The frost isn't on the evaporator it was on the inside of the unit on the back. There were water droplets in a line that then would get frosty. But now it doesn't do that. It is just not cooling.
#4 Posted : Thursday, August 4, 2011 4:56:01 AM(UTC)
Seems like a clogged cap line. If the compressor was hot, and now cold, best to verify the compressor is still good as you will need a pro to clear out the clog, but a bad compressor would make the job cost too high.
momfixesit
#5 Posted : Thursday, August 4, 2011 6:32:30 AM(UTC)
momfixesit
My compressor is still warm..... The unit has been turned off for some quite time since it has not been working properly. Two days ago, I turned it back on to see what would happen. It was running for over 24 hours. The condensation didn't form on the inside of the unit. Everything in the back was working, fan, compressor (warm to the touch) etc. But unit did not get cool inside.
#6 Posted : Thursday, August 4, 2011 6:42:24 AM(UTC)
If the condenser and compressor are warm, the compressor is probably running. I would suspect a bad compressor, or bad refrigerant leak, both rather expensive to fix.
momfixesit
#7 Posted : Thursday, August 4, 2011 6:58:19 AM(UTC)
momfixesit
Is to condenser supposed to be warm to the touch also? Or just the compressor.
#8 Posted : Thursday, August 4, 2011 12:40:05 PM(UTC)
If the condenser coils are cool, your compressor is not running. To replace the compressor start device, you will need to measure things with a meter.
Guest (4)
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Mabe MBC12GAZASS Not Cooling (Refrigerator & Freezer Repair)
by MKDrepair 2/5/2024 5:57:08 AM(UTC)
GE GSS23QSTA not cooling after power outage (Refrigerator & Freezer Repair)
by sfarid123 12/19/2023 7:39:47 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Ge Monogram Integrated Top/Bottom Not Cooling ZICP360NXLH (Refrigerator & Freezer Repair)
by grundyv2 10/7/2023 12:48:51 PM(UTC)
GE botom freezer not cooling (Refrigerator & Freezer Repair)
by Dieselista 10/6/2023 5:39:30 PM(UTC)
Whirlpool WRV986FDEM00 is not cooling (Refrigerator & Freezer Repair)
by Find a fix 9/23/2023 4:03:34 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
Samsung family hub freezer not cooling (Refrigerator & Freezer Repair)
by foster1447 8/20/2023 2:36:12 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
