EdMackie
#1 Posted : Friday, September 25, 2009 2:32:47 PM(UTC)
EdMackie
The dishwasher appears to have no power. The outlet works fine. It just stopped working one day. Any ideas, I'm pretty handy once I get headed in the right direction
#2 Posted : Saturday, September 26, 2009 3:34:41 AM(UTC)
Replacement parts for WHIRLPOOL DU945PWPQ2 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208535431.pdf
A possibility is the fuse, Item 4 in the "Frame and console" section
Next would be the door latch switches
The above assumes that power is getting into the unit and it is not just a bad wire nut connection.
MYAKIMO
#3 Posted : Wednesday, August 3, 2011 10:34:47 PM(UTC)
MYAKIMO
Originally Posted by: denman Go to Quoted Post
hEY THERE, THE TECH SHEET FOR THIS DISHWASHER IS NO LONGER AVAILABLE HERE? ANYWAY YOU CAN SEND ME A LINK FOR ANOTHER ONE PLEASE? THANK YOU
#4 Posted : Thursday, August 4, 2011 1:25:27 AM(UTC)
Please see the attachment
File Attachment(s):
DU945.pdf (195kb) downloaded 14 time(s).
MYAKIMO
#5 Posted : Thursday, August 4, 2011 2:23:49 PM(UTC)
MYAKIMO
My wife went to wash dishes the other day and the whirlpool dishwasher filled up but would not start wash cycle nor drain when I pushed cancel. I checked for clog in hoses. Any suggestons where to start?
#6 Posted : Friday, August 5, 2011 2:09:06 AM(UTC)
You have to do more troubleshooting.
Does the unit seem totally dead?
If yes then the thermal fuse may have blown.
Is the pump getting voltage but not starting?
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
