refrigerator will not cool,not making any noise,it clicks once then after a few seconds it clicks again,could it be the overload relay and capacitor not engaging the compressor.
Yes, most likely it is the relay on the compressor. A quick and easy test is to take it off the compressor, and shake it, if it rattles, it's bad.
