2 Pages<12
twodesk
#11 Posted : Wednesday, December 10, 2008 1:53:51 PM(UTC)
twodesk
It Seem That The Top Part Of The Refrig Is Warmer Then The Bottom Part Is Very Cold Do I Still Have To Take The Back Panel Off
abadfish66
#12 Posted : Wednesday, December 10, 2008 2:04:38 PM(UTC)
abadfish66
1 of 2 things are going on...
1. your fan is not turning fast enough, causing poor air circulation. You should be able to hear the fan turning real good, moving air. If it is not turning very fast, you may have a bad fan....You will also notice like frozen water droplets on the back wall of the freezer...
2. The evaperator is caked full of compacted snow/ice that it is not letting the fan pull air through it properly, to check this, yes you need to remove the back panel. It's held on by like 2 or 4 screws..pretty easy
2.
abadfish66
#13 Posted : Wednesday, December 10, 2008 2:06:37 PM(UTC)
abadfish66
My 1st instinct based on warm temps up top and cold temps low, is the fan not turning like it should, but I'm not there to look, so I need you to check things.
twodesk
#14 Posted : Wednesday, December 10, 2008 2:23:14 PM(UTC)
twodesk
Full Of Ice Lots Of It
abadfish66
#15 Posted : Wednesday, December 10, 2008 2:32:28 PM(UTC)
abadfish66
Down at the bottom of the evaperator coils is a defrost heater, you can look at the glass tube, if it is blackened or greenish in color or both, the heater needs to be replaced. What you need to do now is turn the fridge off, get a hairdryer and melt all that ice, and if the heater is bad, you can order the heater, WR51x10101. After all the ice is melted, put the back panel back on. Your refer will work like normal for the next week to week and a half, enough time for you to get the heater and put it in.
twodesk
#16 Posted : Wednesday, December 10, 2008 3:26:53 PM(UTC)
twodesk
Glass Tube Is Black Is That All I Need The Deforst Heater Or Is There Some More Surprises ? Thanks
abadfish66
#17 Posted : Wednesday, December 10, 2008 3:39:52 PM(UTC)
abadfish66
That is probably it, I'm sure your good
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE side by side PSS26SGPA SS (Refrigerator & Freezer Repair)
by Guest 1/23/2022 3:19:31 AM(UTC)
GE side by side clicks once by compressor then once on board. (Refrigerator & Freezer Repair)
by Schaanman 1/23/2022 2:03:33 AM(UTC)
GE side by side model GSS25KSTASS ice maker auger continues to run (Refrigerator & Freezer Repair)
by RodneyS 5/30/2021 2:59:27 PM(UTC)
GE Side by Side Freezer 25 degrees warmer than set-point (Refrigerator & Freezer Repair)
by reese600 1/21/2021 11:39:19 AM(UTC)
GE side by side starts and stops (Refrigerator & Freezer Repair)
by SethL 12/19/2020 6:58:00 AM(UTC)
GE Side by Side - Water/Ice Dispense (Refrigerator & Freezer Repair)
by USS Pogy 11/5/2020 4:08:04 AM(UTC)
GE Side by side GSHS6LGBBHSS (Refrigerator & Freezer Repair)
by Ksutherland 5/16/2020 10:05:38 AM(UTC)
GE side by side refregator does not start (Refrigerator & Freezer Repair)
by patel_bhavesh100 9/12/2019 5:32:28 AM(UTC)
GE side by side, uneven cooling (Refrigerator & Freezer Repair)
by GLMace 2/28/2019 2:46:16 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
GE side by side, sporadic water and ice dispensing (Refrigerator & Freezer Repair)
by Ramski00 11/25/2018 12:13:04 PM(UTC)
2 Pages<12
