jwest8221
#1 Posted : Tuesday, July 26, 2011 4:31:41 PM(UTC)
jwest8221
Whirlpool duet front load washer filled with water by itself while we were not home of course, front door was open to keep gasket from getting moldy so drum filled with water and spilled out on to floor of laundry room. I'm thinking the inlet water valve leaked and needs replaced, anyone have any other thoughts as to what might fix this problem ?
#2 Posted : Wednesday, July 27, 2011 2:29:12 AM(UTC)
Replacement parts for WHIRLPOOL GHW9100LW2 AUTOMATIC WASHER | AppliancePartsPros.com
I agree with you that it sounds like the water inlet valve.
The open door should have killed power to the valve so most likely it did not seal correctly.
Here is a manual which may help with your repair.
http://appliancedigest.c...g-washers-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
jwest8221
#3 Posted : Friday, July 29, 2011 7:45:33 AM(UTC)
jwest8221
Originally Posted by: denman Go to Quoted Post
Thanks for the advice, I replaced valve and it's working fine now.
#4 Posted : Saturday, July 30, 2011 1:06:28 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool Duet Washer - Possible Faulty Fill Valve (Washer Repair)
by Guest 2/2/2024 4:18:21 PM(UTC)
Whirlpool duet washer not draining (Washer Repair)
by Guest 2/16/2022 8:40:23 AM(UTC)
Whirlpool Duet Washer - Wire broken off connector on harness (Washer Repair)
by Cephalon 1/21/2021 9:33:49 PM(UTC)
Whirlpool Duet Washer Codes (Washer Repair)
by mbocon 3/10/2020 5:04:51 PM(UTC)
Whirlpool duet washer (Dishwasher Repair)
by Julia Johnson 11/1/2017 9:53:41 AM(UTC)
What happened to my Whirlpool Duet washer?? (Washer Repair)
by colbran 10/2/2017 12:01:48 PM(UTC)
Whirlpool Duet Washer (Washer Repair)
by Bmbrouillette 7/2/2017 11:05:32 AM(UTC)
Whirlpool duet washer- won't start after replacing CCU and door latch (Washer Repair)
by Ivanick 5/22/2017 6:07:41 PM(UTC)
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
whirlpool duet washer F06 E02 error (Washer Repair)
by tnafranklin 10/18/2016 12:47:55 PM(UTC)
whirlpool duet washer (Washer Repair)
by Oathose 4/4/2016 7:23:01 PM(UTC)
Whirlpool Duet Washer bellow tore in two. (Washer Repair)
by pitwoman 1/28/2016 5:42:42 PM(UTC)
by CrosbyFamilyFarm 12/31/2015 1:28:32 PM(UTC)
Whirlpool Duet Washer not working (Washer Repair)
by Shanej69 11/23/2015 1:59:18 PM(UTC)
