Whirlpool duet front load washer filled with water by itself while we were not home of course, front door was open to keep gasket from getting moldy so drum filled with water and spilled out on to floor of laundry room. I'm thinking the inlet water valve leaked and needs replaced, anyone have any other thoughts as to what might fix this problem ?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Thanks for the advice, I replaced valve and it's working fine now.
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause. |
