alrome78
#1 Posted : Tuesday, July 26, 2011 6:59:05 AM(UTC)
alrome78
The dispenser is not dispensing ice. The ice maker is producing and there is a low "humming" or "whirling" noise like it is trying to work when the dispenser flap is depressed (engaged) but nothing is coming out.
Can you help?
Thanks!
Joe / APP Team
#2 Posted : Tuesday, July 26, 2011 7:37:26 AM(UTC)
Joe / APP Team
Can you help?
Thanks!
Alrome,
Try this, Remove the ice bin from the freezer, tape or hold the freezer door light switch closed, select cubed ice and press the paddle in. You should hear: the cube solenoid activate, and you should be able to hear and see the auger motor yoke turn in a counterclockwise direction, if the yoke is not turning, check and make sure the motor is not frozen with ice or frost. Otherwise you'd have a bad auger motor. I think, that's where we'll find the problem.
alrome78
#3 Posted : Tuesday, July 26, 2011 8:04:07 AM(UTC)
alrome78
Originally Posted by: Joe / APP Team Go to Quoted Post
Alrome,
Ok, I have tried that and the device is not turning. I looked at the motor, but cannot see any frost damage. How can I test the motor? Or do you think that is done for?
alrome78
#4 Posted : Tuesday, July 26, 2011 8:46:31 AM(UTC)
alrome78
Sorry, did that last message relay properly?
Joe / APP Team
#5 Posted : Tuesday, July 26, 2011 10:51:20 AM(UTC)
Joe / APP Team
Alrome,
I fear the auger motor itself is a "goner",
Part number: AP2991305
Since it makes a noise but doesn't turn/move.
You'll need to empty the freezer, remove power to the refrigerator.
Remove the Yoke from the motor shaft( hold the motor shaft, with a small pair of pliers, behind the yoke, and turn the yoke clockwise to remove it.
Remove the four(4) screws holding the motor bracket assembly to the freezer wall and carefully slide the assembly out, enough to disconnect the wire harnesses, and slide the assembly out of the freezer. Remove the screws holding the motor to the bracket, and reverse the process.
Good Luck,
sandy1124
#6 Posted : Sunday, July 31, 2011 10:06:23 AM(UTC)
sandy1124
I found & fixed my same problem. There are gears that must mesh properly in order to turn the auger that dispenses the ice. If they are frozen over, they cannot mesh. Remove the ice cube bin. You will see one of the gears in the door where the bin sits and the other is underneath the bin. I used a hairdryer to melt the ice build up from both gears, put back the bin and, voila! It works just fine. I don't know what caused the ice to build up there in the first place - maybe using crushed ice and then having the door open too many times on hot days? Anyway, it is an easy fix to an annoying problem.
Joe / APP Team
#7 Posted : Monday, August 1, 2011 5:33:48 AM(UTC)
Joe / APP Team
Sandy,
Thanks for the input. It'll come in handy for future reference.
Guest (4)
Ice dispenser not working on Frigidaire (Refrigerator & Freezer Repair)
by hireyes1414 2/27/2021 12:39:13 PM(UTC)
Kitchen Aide KSFS25FKWH00 Refrigerator water and Ice dispenser not working (Refrigerator & Freezer Repair)
by darioamartinez 6/9/2020 4:12:30 PM(UTC)
GE Frig Ice dispenser not working (Refrigerator & Freezer Repair)
by ttimpone 12/16/2019 9:45:12 AM(UTC)
by BigDaddrock 4/13/2017 6:58:54 AM(UTC)
KitchenAid Refrigerator ice dispenser not working (Refrigerator & Freezer Repair)
by Electricpete 7/8/2015 1:52:40 PM(UTC)
Ice Dispenser Not Working - GE Profile (Refrigerator & Freezer Repair)
by rohan076 12/3/2014 3:21:21 PM(UTC)
Frigidaire ice dispenser not working (Refrigerator & Freezer Repair)
by Hwelch03 11/2/2014 4:14:28 PM(UTC)
Ice dispenser not working(again) (Refrigerator & Freezer Repair)
by t21 8/10/2014 7:58:39 PM(UTC)
Kenmore s/s - Ice dispenser not working (Refrigerator & Freezer Repair)
by mkdamiano 11/16/2013 1:42:15 PM(UTC)
Ice dispenser not working. (Refrigerator & Freezer Repair)
by john simmons 5/18/2013 5:10:26 AM(UTC)
Ice Dispenser not working (Refrigerator & Freezer Repair)
by Grammie 4/22/2013 7:28:05 PM(UTC)
by neoplan205 3/7/2013 4:22:36 PM(UTC)
Water/Ice Dispenser not working (Refrigerator & Freezer Repair)
by Azurescens 2/5/2013 4:21:41 PM(UTC)
Whirlpool ice dispenser not working (Refrigerator & Freezer Repair)
by DIM62 1/12/2013 7:44:42 AM(UTC)
KitchenAid ice dispenser not working (Refrigerator & Freezer Repair)
by mhubbuch 12/22/2012 9:37:55 AM(UTC)
