Mayobeach
#1 Posted : Monday, December 8, 2008 9:49:17 AM(UTC)
Mayobeach
I just moved into the house and the dishwasher was included.
It's a GE Profile Quiet Power III. We've done a couple cycles now and the water does not want to drain. There is about 2-3 inches left in the bottom.
I thought at first that something might be blocked, so i checked all my hoses and water can escape freely.
I noticed that there is a difference between the Quiet II and III, being that i have something called a "Pump Dual" AP2039447. What is it's purpose?
Also, there is a "Valve Flapper" AP2038445, which i was told by the previous owner, could be the problem.
Or, would my problem just be the pump and motor? (On a side note, i can't see the diagrams for my model when looking at the parts, the breakdown diagrams that is).
I need some help!
abadfish66
#2 Posted : Monday, December 8, 2008 9:52:56 AM(UTC)
abadfish66
First off, when you start the machine you do hear water spraying around right?
Is there an airgap on the sink the dishwasher drains through, and then to the disposer, or does it drain straight into the disposer?
Mayobeach
#3 Posted : Monday, December 8, 2008 9:59:21 AM(UTC)
Mayobeach
I am pretty sure the water is being sprayed around right. The drain is plugged directly to the sink.
abadfish66
#4 Posted : Monday, December 8, 2008 10:16:26 AM(UTC)
abadfish66
Does your sink have a disposer, is that where the drain goes to, or just the sink?
Take the drain hose off the sink and stick the end in a bucket, start the dishwasher and after about 30 seconds hit reset or cancel whichever you have, does all the water drain out into the bucket, is there a trickle or nothing at all?
Mayobeach
#5 Posted : Monday, December 8, 2008 10:20:44 AM(UTC)
Mayobeach
It's plugged under the sink into the sinks drainage piping. Once i get home, i'll start a cycle and cancel and see what happens and tell you the results from there.
Mayobeach
#6 Posted : Tuesday, February 3, 2009 10:32:24 AM(UTC)
Mayobeach
I verifed the hoses, no clogs. I did the reset/cancel and does in fact drain. However, the problem seems to happen every 3 or 4 cycles.
carolb4
#7 Posted : Monday, February 9, 2009 6:44:29 AM(UTC)
carolb4
Where is the reset/cancel button?
Mayobeach
#8 Posted : Thursday, March 12, 2009 10:04:54 AM(UTC)
Mayobeach
For me, it's the same button as the "Start"
As for my problem, it hasn't back logged with water for the past few weeks now. I guess it solved itself
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by sanjayg1971 7/1/2015 10:37:25 AM(UTC)
Dishwasher not draining (Dishwasher Repair)
by CTLewis 2/23/2014 1:43:26 PM(UTC)
Amana dishwasher not draining completely (Dishwasher Repair)
by dennis728 11/24/2013 4:26:15 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
Dishwasher not draining, hoses/filter are clear (Dishwasher Repair)
by limon 3/1/2013 8:37:12 AM(UTC)
