mike h
#1 Posted : Monday, December 8, 2008 7:52:06 AM(UTC)
mike h
we have a GE profile prodigy washer. when washing, it will not complete the risnse cycle, won't dispense/drain the fabric softner or spin to dry. was wondering if I should buy your part # AP3140343, a control assembly. Thanks
washer is 5 years old
#2 Posted : Monday, December 8, 2008 4:21:45 PM(UTC)
What is the complete model number of the washer?
mike h
#3 Posted : Monday, December 8, 2008 6:12:59 PM(UTC)
mike h
Wpse4200aoww
mike h
#4 Posted : Monday, December 8, 2008 6:14:16 PM(UTC)
mike h
WPSE4200AOWW
mike h
#5 Posted : Monday, December 8, 2008 6:17:12 PM(UTC)
mike h
Originally Posted by: mike h Go to Quoted Post
WPSE4200AOWW
gene, here's the model # WPSE4200AOWW
thanks
#6 Posted : Tuesday, December 9, 2008 12:36:35 PM(UTC)
Hi Mike,
The first thing I would check is the lid switch (#388 on the break down diagram). You have to remove the front panel to access it.
Here are the break down diagrams for the GE washer Model WPSE4200A0WW
mike h
#7 Posted : Tuesday, December 9, 2008 2:35:32 PM(UTC)
mike h
with the lid open, by using a magnet attached the washing machine where the lid strip would make contact with it seemed to have fooled the machine to think the lid was closed. In the rinse cycle, I could hear the motor running and the a knob on the control panel trying to advance to the next cycle, but it never went there to dispense the fabric softner neither did it spin.
#8 Posted : Wednesday, December 10, 2008 8:25:17 AM(UTC)
Mike,
Remove the front panel and check the belt.
Bypass the lid switch and run the washer.
When the motor runs, does the transmission pulley run too?
