The water stay on the bottom.
Originally Posted by: yteaq  The water stay on the bottom. Yteaq, Could you get us a proper model number from the production tag on the appliance. We can't find any inormation with the number you supplied. Thanks, :) :) :)
kitchen aid model #kud102frss4
Originally Posted by: yteaq  kitchen aid model #kud102frss4 Yteaq, OK, we have a number we can work with(KUDI 02 frss04). And water is in the bottom of the tub, so. Can you hear the drain pump run, when it's in the drain cycle. Part number: AP4320199
Have you disconnected the drain hose from the plumbing, and checked for a clogged drain hose ? You'll need to remove the lower access panel and kickplate to access the drain pump and hoses to check. Good Luck, :) :) :)
