lkbnyc
#1 Posted : Friday, December 5, 2008 1:18:15 PM(UTC)
lkbnyc
I have an Amana over the range microwave that is about 5 years old and out of warranty. Everything works except it does not heat. The lights, sounds, rotating dish, etc., all seem normal but food does not change temperature. Having read multiple postings on this site I think it is probably the magnetron. I can find them for sale online, but would appreciate advice - is this something really hard to replace? Is there any documentation on replacing it?
#2 Posted : Saturday, December 6, 2008 1:34:54 PM(UTC)
Open the control pane. Remove the Red and the White wires from the transformer and check for 120VAC between these wires while the control calls for heat and the door is closed.
If there is no 120VAC then the problem is a bad control board.
If there is 120VAC then check the diode as described in the Service manual.
If the diode is fine then replace the magnetron.
You can find all instructions in the Service manual.
- The part number for the control board is AP428089
- The part number for the diode is AP99472
- The part number for the magnetron is AP4315380
Here are the break down diagrams for the Amana microwave Model ACO1860AS
KitchenAid Magnetron Replacement (Microwave Repair)
by hipchecker 12/28/2021 2:27:22 PM(UTC)
finding a magnetron replacement (Microwave Repair)
by albuquerquemat 6/19/2017 10:11:31 AM(UTC)
by raffellis 11/18/2012 5:26:17 AM(UTC)
magnetron replacement - Need help (Microwave Repair)
by mtbike 6/18/2012 6:19:44 PM(UTC)
by kswelt22 4/5/2012 12:45:08 PM(UTC)
Possible magnetron replacement (Microwave Repair)
by Bob Greene 8/25/2009 7:08:21 AM(UTC)
GE Magnetron replacement! Where does diode go? (Microwave Repair)
by KeithGP 11/29/2008 10:02:48 AM(UTC)
