JTeske
#1 Posted : Saturday, December 6, 2008 11:47:47 AM(UTC)
JTeske
Dryer motor rotates drum. Heat is not initiated. Have checked continuity of hi-limit thermostat, valve coils, thermal fuses, and igniter - all positive. I have removed gas valve assembly and confirmed clean input and output ports.
I do not get continuity on cycling thermostat between purple and orange leads. Please confirm that I should be able to get continuity between these contacts.
Any advice on what might be the problem would be appreciated.
I have broken the igniter coil assy while removing the gas valve assembly so I am replacing that.
Thank you for any help you can give.
libertyappl
#2 Posted : Sunday, December 7, 2008 6:30:43 AM(UTC)
libertyappl
Your cycling thermostat is most likely the culprit it should have continuity!
Nat
kayakcrzy
#3 Posted : Sunday, December 7, 2008 8:03:06 AM(UTC)
kayakcrzy
If looking at the cycling thermostat, and it is a 4 wire thermostat, the terminal at 3 oclock and at 9 oclock will not have continuity. That's normal. You never did mention the flame sensor. If the ignitor does not come on and the high limit thermostat is good, You either have a bad flame sensor or a bad ignitor. You can jump out the flame sensor if you like, and see if it works. Tom ApplianceEducator.com
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 9/12/2022 12:32:58 PM(UTC)
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 5/19/2022 8:57:30 AM(UTC)
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 9/6/2019 11:33:44 AM(UTC)
Maytag DG 612 will not heat in Regular, but will heat in Delicate (Dryer Repair)
by GeorgeGPL 7/22/2019 4:14:22 PM(UTC)
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Furnace will not heat (Heating, Ventilation, and Air Conditioning (HVAC))
by zomalaja 1/3/2017 7:51:36 PM(UTC)
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 2/16/2016 8:37:13 AM(UTC)
lower element will not heat up (Oven Repair (including Ranges and Cooktops))
by bill weiss 1/27/2016 1:35:36 PM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 11/11/2015 2:05:29 PM(UTC)
Dishwasher Will Not Heat Up (Dishwasher Repair)
by jshep3 11/4/2015 12:12:49 PM(UTC)
