RC Cola
#1 Posted : Saturday, July 9, 2011 7:09:16 AM(UTC)
RC Cola
:confused: My Whirlpool washer initially would not spin on the delicate and hand wash cycles. Then the spin started failing in the normal cycle. Sometimes it spins and sometimes it does not. I called a repairman and he told me the timer is bad. I am not sure this is the problem.
I have continued to use the washer and now I have noticed that when agitating, the agitator is getting weaker as the number of minnutes left on the wash cycle decreases. The last time I washed I even smelled a light burning smell.
Any idea what is causing this? I've read that it could be the coupling, the clutch, the transmission, clutch basket drive, tub drive box and so many other possibilities.
Does anyone have any ideas as to what is going on with my washer?
Thanks for your help
RC Cola
#2 Posted : Monday, August 8, 2011 6:28:20 PM(UTC)
RC Cola
:) My problem was the clutch.....I have a direct drive Whirlpool washing machine.
Another user had a similar problem with his machine and it was due to the brake shoes.
If you are having a problem with your spin cycle you can get more info here: Whirlpool washer is not spinning
Good luck!
Samsung Dryer Spinning Problem (Dryer Repair)
by pjenkins5212 3/31/2020 11:49:07 AM(UTC)
Maytag Bravos agitation and spinning problem (Washer Repair)
by rosocarne 5/1/2016 9:34:54 AM(UTC)
Kenmore 80 series washer spinning problems (Washer Repair)
by dw17dw17 2/11/2014 9:53:23 AM(UTC)
Whirlpool Washer spinning problem (Washer Repair)
by KSS 1/26/2013 9:39:50 PM(UTC)
GE Top Load washer agitating & spinning problems (Washer Repair)
by chedrick 11/9/2012 6:13:51 PM(UTC)
Whirlpool washer spinning problem (Washer Repair)
by Bob1958 10/21/2012 7:10:26 AM(UTC)
Spinning Problems (Washer Repair)
by gate1 1/28/2012 12:26:56 PM(UTC)
Whirlpool front loading washer spinning problems (Washer Repair)
by godp1301 2/22/2010 7:00:10 AM(UTC)
Amana washer Bearing and Spinning problem (Washer Repair)
by papabear1245 5/30/2009 2:35:35 PM(UTC)
Spinning Problem (Washer Repair)
by JMS1953 12/14/2008 4:15:43 PM(UTC)
