MY GE REFRUGERTOR DSF25KGTB BG IS NOT WORKING PROPERLY. ITS SETUP 0 DEGREE IN FREIDGER SECTION AND 37 DEGREE IN REFRIGERTOR SECTION. EVERY FEW DAYS ( IN ABOUT 4 OR 5 DAYS) THE REFRIGERTOR SECTION GO TO 50 AND FREIDGER SECTION GO TO 20 DEGREE AND THEN IT WILL START WORKING AGAin normaly. I CLEAN COIL, I CHECKED/TESTED 2 THERMISTOR AND IT READING OK AS PER YOUR INSTRUCTION VIDIO. WHAT IS WRONG ? WHAT ELSE I SHOULD I CHECK ? THANKS ANIL DESAI
Remove the motherboard in the back and check the solder connections at the big power relay. If ok, probably a bad motherboard AP4436216 Also, when it fails, verify both condensing and evaporator fans are running
Originally Posted by: richappy  Remove the motherboard in the back and check the solder connections at the big power relay. If ok, probably a bad motherboard AP4436216 Also, when it fails, verify both condensing and evaporator fans are running I checked and everything is look good. I read on the internet that GE has recalled this mother bord (wr55x10942) do you have any information on this recall ? Hioe can I fiond out more about this ? what is contact phon number foe GE for this recall ? Thanks Anil Desai
