ANILDESAI
#1 Posted : Thursday, June 23, 2011 2:26:00 PM(UTC)
ANILDESAI
MY GE REFRUGERTOR DSF25KGTB BG IS NOT WORKING PROPERLY. ITS SETUP 0 DEGREE IN FREIDGER SECTION AND 37 DEGREE IN REFRIGERTOR SECTION. EVERY FEW DAYS ( IN ABOUT 4 OR 5 DAYS) THE REFRIGERTOR SECTION GO TO 50 AND FREIDGER SECTION GO TO 20 DEGREE AND THEN IT WILL START WORKING AGAin normaly. I CLEAN COIL, I CHECKED/TESTED 2 THERMISTOR AND IT READING OK AS PER YOUR INSTRUCTION VIDIO. WHAT IS WRONG ? WHAT ELSE I SHOULD I CHECK ?
THANKS
ANIL DESAI
#2 Posted : Saturday, June 25, 2011 5:37:06 AM(UTC)
Remove the motherboard in the back and check the solder connections at the big power relay. If ok, probably a bad motherboard AP4436216
Also, when it fails, verify both condensing and evaporator fans are running
ANILDESAI
#3 Posted : Thursday, July 7, 2011 4:57:05 PM(UTC)
ANILDESAI
I checked and everything is look good.
I read on the internet that GE has recalled this mother bord (wr55x10942) do you have any information on this recall ? Hioe can I fiond out more about this ? what is contact phon number foe GE for this recall ?
Anil Desai
Samsung Refrigertor coils contantly freeze (Refrigerator & Freezer Repair)
by fawbre 7/16/2014 7:31:48 AM(UTC)
RCA Refrigertor leak inside (Refrigerator & Freezer Repair)
by Thomas A 4/30/2013 11:36:24 AM(UTC)
Water running out from under GE refrigertor/freezer (Refrigerator & Freezer Repair)
by EdwinY 7/23/2012 9:04:28 PM(UTC)
refrigertor not cooling (Refrigerator & Freezer Repair)
by raybell 5/3/2012 1:45:38 PM(UTC)
Refrigertor (Refrigerator & Freezer Repair)
by FAUDEL 4/25/2012 5:00:14 PM(UTC)
my refrigertor whirlpool gold s/s (Refrigerator & Freezer Repair)
by david snelling 2/7/2012 10:23:35 AM(UTC)
refrigertor freezer (Refrigerator & Freezer Repair)
by markcorneliussr 4/12/2010 2:31:35 PM(UTC)
Ge Refrigertor Freezes Up (Refrigerator & Freezer Repair)
by brodzin504@bellsouth.net 9/17/2009 7:53:46 AM(UTC)
GE refrigertor not working property (Refrigerator & Freezer Repair)
by vdnusa 6/5/2009 6:19:10 PM(UTC)
GE Profile Refrigertor (Refrigerator & Freezer Repair)
by ppd1942 12/22/2008 2:59:18 PM(UTC)
refrigertor leaks water on floor (Refrigerator & Freezer Repair)
by pamela 333 9/22/2008 7:21:45 AM(UTC)
