macnchez
#1 Posted : Tuesday, July 5, 2011 3:19:55 PM(UTC)
macnchez
Top burners work - broiler works - oven will not heat up. Igniter lights a bright yellow - burner trys to light but very little flame to heat the oven up. Takes well over an hour to preheat if it does at all. Is there a gas regulator? Help
Ardvaark
#2 Posted : Tuesday, July 5, 2011 3:55:54 PM(UTC)
Ardvaark
Check the hole where the gas actually comes out for a clog. If not, sound like an internal clog, might need a new gas valve.
Ardvaark
macnchez
#3 Posted: : Wednesday, July 6, 2011 4:41:20 AM(UTC)
macnchez
Ardvaark
I don't have a repair manual. I must have to remove the back of the unit to get to the working parts? Just trying to make sure I use the easiest way.
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
Samsung Range and Oven Won't Heat Up (Oven Repair (including Ranges and Cooktops))
by neweyess 8/19/2013 5:13:28 AM(UTC)
Kenmore gas oven won't heat up properly (Oven Repair (including Ranges and Cooktops))
by Black Cherry 3/27/2013 11:12:55 AM(UTC)
The oven won't heat up. The pilot is lit and not heating oven (Oven Repair (including Ranges and Cooktops))
by Hazelave.corp 11/21/2012 3:55:15 PM(UTC)
whirlpool oven won't heat up (Oven Repair (including Ranges and Cooktops))
by smeighan 11/19/2012 4:38:18 PM(UTC)
Oven won't heat up but broiler works fine (Oven Repair (including Ranges and Cooktops))
by NJ Mom of 3 11/11/2012 4:42:15 PM(UTC)
Oven won't heat up? element and/or sensor problem?? (Oven Repair (including Ranges and Cooktops))
by renzandjo 7/18/2012 9:26:23 AM(UTC)
kitchenaid oven won't heat up (Oven Repair (including Ranges and Cooktops))
by susanm 6/5/2012 6:29:46 AM(UTC)
Oven won't heat up after self cleaning cycle (Oven Repair (including Ranges and Cooktops))
by ToughTags 2/28/2012 3:15:55 PM(UTC)
Maytag Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by Petezr 1/25/2012 6:27:38 PM(UTC)
GE Wall Oven Won't heat up (Oven Repair (including Ranges and Cooktops))
by tejyam@hotmail.com 1/17/2012 1:29:54 PM(UTC)
Oven won't heat up, need help! (Oven Repair (including Ranges and Cooktops))
by dogrobber13 8/16/2011 8:09:08 AM(UTC)
Oven won't heat up (Oven Repair (including Ranges and Cooktops))
by Haf 6/12/2011 3:27:40 PM(UTC)
Maytag Gas Oven Won't heat Up (Oven Repair (including Ranges and Cooktops))
by cjklein1 4/22/2011 10:01:07 AM(UTC)
Maytag oven won't heat up (Oven Repair (including Ranges and Cooktops))
by steelerfan349 10/22/2010 2:42:24 AM(UTC)
