Top burners work - broiler works - oven will not heat up. Igniter lights a bright yellow - burner trys to light but very little flame to heat the oven up. Takes well over an hour to preheat if it does at all. Is there a gas regulator? Help
Check the hole where the gas actually comes out for a clog. If not, sound like an internal clog, might need a new gas valve.
Ardvaark
Originally Posted by: Ardvaark  Check the hole where the gas actually comes out for a clog. If not, sound like an internal clog, might need a new gas valve.
Ardvaark I don't have a repair manual. I must have to remove the back of the unit to get to the working parts? Just trying to make sure I use the easiest way.
