Louisle16
#1 Posted : 14 years ago
Louisle16
I REPLACED 2 DOOR SWITCHES - Door sensing switch (AP2024337) and Switch - monitor (AP2024338) the microwave did not work. When I open the door, the display totally disappeared. I have to reset the clock. Then the vent fan, vent fan boost and the surface light works. When I operate, the microwave beep once and the light inside flickering few second then nothing happened. Please help me identify what's next i should check. Thank you for your advice. Louis
Ardvaark
#2 Posted : 14 years ago
Ardvaark
Door interlock switches are tricky. They are not all created equal. Some are 2 prong, some are 3 prong. Some are N.C - N.O. some are N.O. - N.C. with the connectors in the same place. Must pay careful attention to what the original pattern is.
Ardvaark
GE Spacemaker XL1800 (Microwave Repair)
by Dsteve 10 years ago
GE Spacemaker xl1800 vent fan not working (Microwave Repair)
by titannero 12 years ago
GE Spacemaker XL1800 - Making Buzzing Noise (Microwave Repair)
by bunk60 14 years ago
GE Spacemaker XL1800 running when you open door (Microwave Repair)
by andreah 14 years ago
GE Spacemaker XL1800 won't heat (Microwave Repair)
by doanhtran@gmail.com 14 years ago
by sman2626 14 years ago
by guilty 14 years ago
Ge spacemaker xl1800, Fan motor, light and table not working (Microwave Repair)
by mdorsey 14 years ago
GE Spacemaker XL1800 hum/buzz noise but heating works (Microwave Repair)
by faraday 16 years ago
GE Spacemaker XL1800 control panels locks up (Microwave Repair)
by usd777 16 years ago
GE Spacemaker XL1800 will only heat when vent fan is on (Microwave Repair)
by melissams17 16 years ago
GE Spacemaker XL1800 microwave making fluttering sound on startup (Microwave Repair)
by madhuvan 16 years ago
by gotkwah 16 years ago
GE Spacemaker XL1800 stopped heating and awful smell (Microwave Repair)
by perplexed 17 years ago
