Louisle16
#1 Posted : Tuesday, June 28, 2011 11:13:46 AM(UTC)
Louisle16
I REPLACED 2 DOOR SWITCHES - Door sensing switch (AP2024337) and Switch - monitor (AP2024338) the microwave did not work. When I open the door, the display totally disappeared. I have to reset the clock. Then the vent fan, vent fan boost and the surface light works. When I operate, the microwave beep once and the light inside flickering few second then nothing happened. Please help me identify what's next i should check. Thank you for your advice. Louis
Ardvaark
#2 Posted : Tuesday, July 5, 2011 3:45:34 PM(UTC)
Ardvaark
Door interlock switches are tricky. They are not all created equal. Some are 2 prong, some are 3 prong. Some are N.C - N.O. some are N.O. - N.C. with the connectors in the same place. Must pay careful attention to what the original pattern is.
Ardvaark
GE Spacemaker XL1800 (Microwave Repair)
by Dsteve 11/10/2014 5:41:47 PM(UTC)
GE Spacemaker xl1800 vent fan not working (Microwave Repair)
by titannero 1/11/2013 6:27:35 AM(UTC)
GE Spacemaker XL1800 - Making Buzzing Noise (Microwave Repair)
by bunk60 7/20/2011 2:07:03 PM(UTC)
GE Spacemaker XL1800 running when you open door (Microwave Repair)
by andreah 6/30/2011 9:00:53 AM(UTC)
GE Spacemaker XL1800 won't heat (Microwave Repair)
by doanhtran@gmail.com 4/12/2011 11:31:47 AM(UTC)
by sman2626 1/11/2011 6:48:59 PM(UTC)
by guilty 11/25/2010 5:17:36 AM(UTC)
Ge spacemaker xl1800, Fan motor, light and table not working (Microwave Repair)
by mdorsey 10/22/2010 5:23:57 AM(UTC)
GE Spacemaker XL1800 hum/buzz noise but heating works (Microwave Repair)
by faraday 4/11/2009 8:08:15 PM(UTC)
GE Spacemaker XL1800 control panels locks up (Microwave Repair)
by usd777 4/6/2009 7:53:02 AM(UTC)
GE Spacemaker XL1800 will only heat when vent fan is on (Microwave Repair)
by melissams17 3/15/2009 2:34:21 PM(UTC)
GE Spacemaker XL1800 microwave making fluttering sound on startup (Microwave Repair)
by madhuvan 3/9/2009 10:23:07 PM(UTC)
by gotkwah 11/4/2008 4:18:35 AM(UTC)
GE Spacemaker XL1800 stopped heating and awful smell (Microwave Repair)
by perplexed 12/26/2007 12:20:01 PM(UTC)
