john matz
#1 Posted : Tuesday, June 28, 2011 2:35:00 PM(UTC)
john matz
Dryer maintains lowest heat at all heat settings. Very slow dry. Also when door is opened with time remaining the heat doesn't shut off even though the drum ceases to rotate and the fan stops. When the dial is moved to off the heat shuts off. Suspect thermostat and possibly heating element.
#2 Posted : Tuesday, June 28, 2011 4:27:57 PM(UTC)
Looks like your model number is missing 3 digits at the front.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run all the time on a low heat depending how it grounded.
john matz
#3 Posted : Wednesday, June 29, 2011 10:53:02 AM(UTC)
john matz
Denman,
Thanks for your reply. The first three digits are 110.I think my major concern is that the heating element won't shut off when the dryer door is opened mid cycle.The door can then be closed and if the start button is not depressed to continue the cycle then the heating element continues to heat risking fire. This may be the timer or the on off switch but that exhausts my ideas.
I suppose the thermostat which is a common failure item on these dryers could also be involved. At any rate thanks for your help.
#4 Posted : Thursday, June 30, 2011 2:29:16 AM(UTC)
Replacement parts for KENMORE 11067902790 | AppliancePartsPros.com
I tried to find a wiring diagram and also a actual parts breakdown diagram but had no luck with either.
All I can tell you is that the unit is a Whirlpool.
My original post is still valid.
The unit has 2 centrifugal switches on the motor. They are activated when the motor gets close to operating speed. One of them closes to provide power to the heater so that there is air flow over the heating coils before they turn on.
For some reason your unit's heater is on with no motor rotation and a grounded element is the most common cause.
Here is a good link with basic dryer repair info
http://www.applianceaid.com/dryers.html
john matz
#5 Posted : Thursday, June 30, 2011 9:53:51 AM(UTC)
john matz
Dear Denman,
Thanks so much for your assistance. I will check out the element which would be an easy and relatively inexpensive fix.
Sincerely,
John Matz
john matz
#6 Posted : Wednesday, July 20, 2011 11:56:53 AM(UTC)
john matz
Originally Posted by: john matz Go to Quoted Post
Dear Denman,
Sincerely,
John Matz
Hello Denman,
I changed the heating element and evertything was fixed. Thanks so much for your guidance.
john matz
#7 Posted : Wednesday, July 20, 2011 11:59:14 AM(UTC)
john matz
Dear Denman,
Thanks so much for your advice. I changed the heating element and all the problems were solved. What a Guy!!
Sincerely,John Matz
#8 Posted : Wednesday, July 20, 2011 12:38:46 PM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
Belarus Guest 6/11/2024 9:40:58 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
