Darren
#1 Posted : 17 years ago
Darren
I am not sure about the age of the washer. I changed the agitators about 4 months ago and everything has been fine. Today we heard a different noise and it was the motor running but it is not spinning.
From what I can tell look at the breakout it could be a clutch?
What do you think and what ever you suggest is it hard to replace?
Darren
jdappl07
#2 Posted : 17 years ago
jdappl07
if the machine will not aggitate if is the motor coupling if it does then its a clutch also see if something is in the pump
angcal
#3 Posted : 17 years ago
angcal
My GE Washer model # (wpsf4170w0aa) my ge washer mackes loud moises when spinning and if the load is slightly heavy it will not spin can you help
#4 Posted : 17 years ago
You have a Whirlpool washer! If it will not agitate also=bad coupler.
If failed in spin, you may have something caught in the tub or dragging brake shoes. Shine a light in basket and check for stuff, if ok, replace the coupler and turn tranny coupler clockwise till the basket starts to spin. If hard to turn with one hand, you have dragging brake shoes. Post results.
#5 Posted : 17 years ago
Hi angcal
The first thing I would check is the belt. Replace it if it's worn out.
If there is nothing wrong with the belt then most likely the problem is a bad transmission.
- Here are the break down diagrams for the GE washer Model WPSF4170W0AA
Good luck.
Whirpool washer will not spin (Washer Repair)
by Guest 3 years ago
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 4 years ago
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 5 years ago
Washer will not spin (Washer Repair)
by lftfield09 8 years ago
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 8 years ago
washer will not spin out.. (Washer Repair)
by coastie1160870 8 years ago
GE washer will not spin (Washer Repair)
by MS104 9 years ago
Maytag Atlantis Washer will not spin (Washer Repair)
by lvavis 10 years ago
by howard6168 10 years ago
Kenmore 800 Washer will not spin (Washer Repair)
by AnneKenzie 10 years ago
Frigidaire Washer will not spin (Washer Repair)
by luvmylars 10 years ago
washer will not spin out (Washer Repair)
by kdwarren16yrs 10 years ago
ge profile washer will not spin (Washer Repair)
by ron dog 10 years ago
Washer will not spin/drain (work) (Washer Repair)
by dupdc 11 years ago
Whirlpool Cabrio Washer Will Not Spin (Washer Repair)
by pacdave 11 years ago
