richardzing
#1 Posted : Saturday, November 29, 2008 9:01:18 AM(UTC)
richardzing
Hi.
Whilpool Duet side load.
When it is turned on in any cycle as soon as it starts to spin it clicks, stops and flashes panel and shuts off.
libertyappl
#2 Posted : Sunday, November 30, 2008 6:19:40 AM(UTC)
libertyappl
Does it give a code?
Nat
kayakcrzy
#3 Posted : Sunday, November 30, 2008 7:00:23 AM(UTC)
kayakcrzy
Try unplugging the washer, and takeing the bottom panel off, and right in the front middle, once you get the front off is the pump. You will see right on the front of it, that the front will screw off, it could be full of stuff, and that is why it could be doing what it is doing. When you do this it will help to pull the washer away from the wall, and lean it back, and rest it on the back wall, so the water will stay in the back of the tub, when you take the cover off the pump. Let me know. Tom ApplianceEducator.com
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
