My ice dispenser cover won't close all the way. There is a pin that holds the door flap and lever in place. This pin goes through a hole and into a slot. The slot part is broken off so the pin won't stay in place. This seems to be a part molded right on to the panel in the fridge. I could only find all the parts, but not the panel (unless I'm missing something). I looked here Model IS25AGXRQ00, does anyone have an idea?
I did not get clear which panel did you mean. Can you refer to the numbers on the diagram? Gene.
