Dispenser Front parts for Whirlpool KSRY25CVMS01 - AppliancePartsPros.comI have this refrigerator and the part that i need on this drawing is #1 but it does not give me the option of buying it. The cubes were falling out and water was dripping so I then noticed the door would not shut. After taking apart I found out the part 1 on the drawing is broken that holds part 7 and 11 How can I buy part 1 from this drawing? When i tried to remove it appears that maybe it is glued/taped to the door and quite difficult. I am concerned that i cannot even remove it at all to fix the ice dispenser. My attempt to remove caused it to bend so I stopped to avoid further damage. Right now my ice dispenser is taped shut and not usable. I taped it to avoid the warm air from melting the ice. We are now just opening the door and removing the ice manually.
Groups: Expert
That part is a non-serviceable item and I've never needed one. You might just need Part# 8201649
Thanks but those parts are not broken. The part 1 from the diagram that these connect to. I have since determined that it requires buying the entire freezer door as this is an all in one part and cannot be solid separately. $550+
Groups: Expert
Ka-Ching!! Get some epoxy and super glue and be creative.
