LJohnson910
#1 Posted : Friday, June 17, 2011 8:02:57 AM(UTC)
LJohnson910
My Kenmore Electric Dryer will run when you push the start button but will stop when you release the button. If the button is held in it will run for just a few seconds and then stop even though the button is being held in. Once the dryer stops, it won't start again for a few minutes. Thought it was a start button problem - but replaced the start button and the problem is still there. What should I check next? :confused:
Thanks for any help that can be provided.
gabe_1981
#2 Posted : Friday, June 17, 2011 8:05:20 AM(UTC)
gabe_1981
You got a bad motor ... Replacing the motor will solve your problem.
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
by steve615 1/31/2017 6:30:27 PM(UTC)
Dryer won't stay on? (Dryer Repair)
by BHReach 12/12/2014 9:41:49 AM(UTC)
GE gas dryer won't stay on (Dryer Repair)
by Bearjohnson 2/26/2013 10:36:11 PM(UTC)
Dryer Won't Stay On..If you hold the start button dryer runs fine (Dryer Repair)
by nickbert 2/27/2012 11:30:06 AM(UTC)
by Mac22 11/29/2011 4:18:45 PM(UTC)
by amabear 2/21/2011 12:01:38 PM(UTC)
by ibgreeen30 9/23/2009 12:42:58 PM(UTC)
by ade 5/22/2009 12:08:39 PM(UTC)
Dryer won't stay on unless I keep my finger (Dryer Repair)
by Lisedryer 5/16/2009 11:43:49 AM(UTC)
by mtamplin 5/3/2009 12:42:19 PM(UTC)
Dryer won't stay on unless "push to start" switch is continuously pressed in (Dryer Repair)
by camalot 1/29/2009 9:36:32 AM(UTC)
by JetRanger 3/22/2008 11:01:40 AM(UTC)
