AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer Won't Stay On..If you hold the start button dryer runs fine
Dryer Won't Stay On. Only if you hold the start button in the dryer will run like normal ignites heats timer works bower works Thanks in-advance. Nick
Hi Nick, There are 2 identical relays and the control board inside the control panel. The relay with the 2 blue wires connected to the large terminals is the motor relay while the relay with the 2 red wires connected to it is the heater relay. To check the motor relay switch the motor and the heater relays by swapping the wires. Start the dryer as you always do. If the motor will start normally, replace the motor relay. If the same problem still exist, replace the control board. - The motor relay Part number: AP3037419
Thanks for the info I did cross the wires and still the same I thinks it's the control board as you said, are they know for going on this model? Also I forgot to say that I cant get it into test mode. Thank you Gene...
The new control board should fix it.
Dryer Repair
