BarbaraStan
#1 Posted : 16 years ago
BarbaraStan
My washer fills up with water (only the cold water) and continues to fill even though the washer is unplugged. The only way I can turn it off is close the cold water valve going into the washer. I had quite a flood, before I discovered it wasn't shutting off. Is this a water inlet valve problem?
Thanks:confused:
v2k04
#2 Posted : 16 years ago
v2k04
Yes.........
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 9 months ago
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 10 months ago
GE Top load washer not draining (Washer Repair)
by Guest 10 months ago
Washer won’t spin with load (Washer Repair)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 10 months ago
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 10 months ago
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 10 months ago
GE Profile Washer not draining and water not hot (Dishwasher Repair)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 10 months ago
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 10 months ago
Whirlpool duet washer front load (Washer Repair)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 11 months ago
Dishwasher won't work. (Dishwasher Repair)
by Guest 11 months ago
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 11 months ago
GE washer grinding noise (Washer Repair)
by gefixin 11 months ago
