Replacement parts for FRIGIDAIRE FRS26HF5AB3 Frigidaire/refrigerator | AppliancePartsPros.comHere is the tech sheet.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389607.pdfYou do not have a defrost timer. The unit uses an adaptive defrost control (Item 23 in Section 5)
First you have to find out what runs and what does not.
Compressor, condenser/compressor fan and the evaporator fan.
Also is the compressor on all the time or is it cycling on/off?
If it is cycling then it could be a thermostat problem.
If on all the time remove the cover from inside the freezer so you can inspect the coils.
If there is no frost por just frost in one area you have a sealed system problem.
Note: This test must be done after the unit has run a couple hours. If checked right after a defrost cycle there will be no frost.
If they are heavily iced/frosted over you have a defrost problem.
Do not let them defrost
If yes.
Manually force a defrost cycle, see the tech sheet. The fans and compressor will turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 21 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
