2 Pages12>
ccredsox
#1 Posted : 16 years ago
ccredsox
All of the sudden a loud humming noise is coming from the machine. Sounds like a motor is stuck or something. Are there belts on this model that could have broken and need to be replaced? I checked the inlet screens for blockage and the drain pipe (figured I would try the easy stuff first) but no luck. The machine is still filling fine but I think its something wrong with the spin cycle. Any help would be greatly appreciated!
ccredsox
#2 Posted : 16 years ago
ccredsox
please help!
v2k04
#3 Posted : 16 years ago
v2k04
Check the pump there may be something in it and if there is it will make a horrific howl,squeal,whatever
ccredsox
#4 Posted : 16 years ago
ccredsox
Is the best way to check the pump by tipping over the machine and accessing it that way?
Thanks!
magician59
#5 Posted : 16 years ago
magician59
If it drains, but doesn't spin, you'll need to replace the motor coupler assembly (a relatively easy job).
ccredsox
#6 Posted : 16 years ago
ccredsox
and what is the best way to get access to this coupler assembly?
ccredsox
#7 Posted : 16 years ago
ccredsox
So I tipped over the washer to gain access to the pump and coupler and they both seem fine. I can spin the internal pump (thingy) which in turn rotated the coupler. I couldn't find anything restricting the flow of water either. After I uprighted the machine I turned it on and It was making the same noise; a loud grind/squealing noise that sounds as if its something that rotates. It only happens during the spin cycle and the machine continues to fill and drain fine.
Help!
#8 Posted : 16 years ago
Pull off the control panel screws, tilt it back and remove the lid switch plug and the top panel clips. Then take off the outer cover, remove the pump and motor.
Turn the coupler clockwise until the spin basket starts to turn. If very hard to turn it further, you either have something obstruction in the tub, of bad brake shoes.
ccredsox
#9 Posted : 16 years ago
ccredsox
Is it straight forward to take the outer cover off? A handful of 3/8" Hex Heads accessible from the bottom?
#10 Posted : 16 years ago
Your panel screws are in the back on each side, just unscrew both pull forward and tilt panel back.
I would advise to fix this soon, I have seen too many burnt motors from this kind of failure!
Loud Humming noise (Microwave Repair)
by fjmcfall 10 years ago
Whirlpool refrigerator has a loud humming noise (Refrigerator & Freezer Repair)
by jkjk 13 years ago
Washer is working fine, but makes loud humming noise... (Washer Repair)
by erica2713 14 years ago
Kenmore coldspot fridge making a new loud humming noise? (Refrigerator & Freezer Repair)
by CRISBD 14 years ago
Dishwasher started making loud humming noise (Dishwasher Repair)
by desh 15 years ago
Maytag Performa loud humming noise (Washer Repair)
by a1_sullivan 15 years ago
Intermittent loud humming noise (Refrigerator & Freezer Repair)
by clarencew 16 years ago
Microwave makes loud humming noise (Microwave Repair)
by aussie downunder 16 years ago
by Fritzauf 17 years ago
Spacemaker JVM1660SB008: No Heating Loud Humming Noise (Microwave Repair)
by Doppan 17 years ago
2 Pages12>
