3 Pages<123>
JESQUEDA
#11 Posted : 14 years ago
JESQUEDA
I realize this is an old post, but i just wanted to share with everyone. I called the recall hot line and yes my washer is falls under the recall they are mailing my the new control board and sears in coming out in 12 days to install it. This post really helped me out and saved me a lot of money because i was getting ready to call sears out on monday!! Thank You to everyone who was involved in this thread. :rolleyes:
RECALL # 1-800-659-7026
THEY ONLY NEED THE MODEL # AND SERIAL #
sidfink43
#12 Posted : 14 years ago
sidfink43
Fantastic! thanks for sharing that with everyone.
DrShannae
#13 Posted : 14 years ago
DrShannae
I am so glad I found this posting! I am all of a sudden having the exact same problem with my washer. I bought my machine in September 2009 and am out of warranty. I can't get a service call until the middle of next week. I am going to try the recall number tomorrow to see if my machine qualifies, but in the meantime how do I get the water out of the machine? Also if it qualifies for the recall does Sears cover the necessary work to fix it all? Thanks everyone for your help!
gunny4852@yahoo.com
#14 Posted : 14 years ago
gunny4852@yahoo.com
where did you get the instructions for the automatic diagnosis and where or how did you reset the pressure sensor
Originally Posted by: RangerRickT Go to Quoted Post
Today, we too got the Ld fault code with an Oasis (110.27082602) washer of similar vintage. I initiated the automated diagnostics which displayed two saved/logged fault codes: F51 and F32. The automated diagnostics did not show a failure, and the technician's troubleshooting guide had numerous manual initiated tests to try - though none exactly matched the conditions of Ld code with empty washer tub. I tried all the tests without finding an error; with the last test, I eventually reset the pressure sensor zero reading. This action seemed logical as the washer drain pump would continue to run after emptying the tub; it didn't seem to "know" that it was empty and move onto the spin cycle. This reset worked for now - we've done 3-4 loads with no problem. I have my fingers crossed that I don't have to replace the control board!!
Joe / APP Team
#15 Posted : 14 years ago
Joe / APP Team
Gunny,
The Technical Data Sheet, for your machine should be attached to the inside of the front cabinet panel, in an envelope.
(you can access it by raising the top of the washer, or from underneath, by raising the front of the washer).
It'll have everything you need to run the diagnostic codes,test and operate individual components, etc.
Don't know your present circumstances or error code(s), but if you're getting the "LD" code, That code stands for "Long Drain", the control board expects to see a change in the resistance of the water level circuit, within a certain amount of time.
If you're positive , you have no kinks or clogs in the drain hose, or drain pump, if you're sure the air dome hose( the palstic tube on the right rear side of the tub, going up to the control board) is not clogged or kinked, you will need a new control board.
Part number: AP4360738
Recalibrating / adjusting the control is a "temporary" repair, and you will start getting the "LD" code eventually.
Good Luck,
JnCGeorge
#16 Posted : 12 years ago
JnCGeorge
how do you reset the pressure sensor?
Joe / APP Team
#17 Posted : 12 years ago
Joe / APP Team
JnC, You should find the tech data / information sheet attached to the inside of the front panel of the washer. Page 6 of the manual will advise you of the procedure and programming of the control if needed.
If the manual is missing, we've attached a "basic" manual for the model number you supplied.
File Attachment(s):
Tech%20Sheet%20-%20W10026571.pdf (364kb) downloaded 100 time(s).
JnCGeorge
#18 Posted : 11 years ago
JnCGeorge
thank you for the response. i found and used the sheet, however we did not fix the multiple problems and bought a new LG washer.
Joe / APP Team
#19 Posted : 11 years ago
Joe / APP Team
JnC, Sometimes that can occur. Time and money seem to be the most concerning factor.
Good Luck with the new washer.
laxmom2
#20 Posted : 11 years ago
laxmom2
I just wanted to let others know that I have model #110.27082604 and it is also recalled. I called the phone number above and at first they told me that it wasn't recalled. After explaining that I was having the SAME problems as the other model number, some how my model number was ALSO recalled. So, I am now waiting for my control board to arrive to see if it fixes my problem! I don't know that I will purchase with Sears again considering I was NEVER notified of this recall and even has an extended warranty with them :( SO SAD SEARS!!!
3 Pages<123>
