james429
#1 Posted : Wednesday, November 19, 2008 12:25:15 PM(UTC)
james429
I am trying to remove the agitator on my old maytag A511. The charts show a bolt in side of agitator. I find no such bolt. Was there more than one series of this module. Serial No 111314 LC. Do I just try to pry the agitator loose or what?
james429
Drags1998
#2 Posted : Wednesday, November 19, 2008 1:39:37 PM(UTC)
Drags1998
NO!! There IS a 1/4" headed screw half way down the side of the agitator!!!!! I know it might hard to see. It should be a little more than 1/2 way down the side. I'm quite sure you'll find it, If not, give it a RIP and see if it will come off!!!
james429
#3 Posted : Thursday, November 20, 2008 12:27:21 PM(UTC)
james429
Dear Draggs 1998, I searcher the agitator completely. There is no
bolt, nut or screw. What do you mean by give it a rip?
james429
magician59
#4 Posted : Thursday, November 20, 2008 12:36:34 PM(UTC)
magician59
Remove the softener cup. The section it comes out of just pops off. Inside the remaining section is a 1/2 inch bolt. Unscrew this and the agitator will come right off.
james429
#5 Posted : Thursday, November 20, 2008 12:51:36 PM(UTC)
james429
Dear Magician59 there is no bolt inside of agitator. Only thing I can see
is plastic that is part of agitator.
james429
magician59
#6 Posted : Thursday, November 20, 2008 1:06:39 PM(UTC)
magician59
If no inside bolt, and no side screw (located just above the base, where it begins to sweep upward), then you should be able to pull it directly off. You may need to rock it side to side as you're pulling up.
#7 Posted : Friday, November 21, 2008 1:22:48 AM(UTC)
Groups ready for retrieval: Senior Expert
You have been a member since:: 9/10/2007(UTC)
You can also use a rope and 2X4 to pry it off.
Removing agitator, GE washer (Washer Repair)
by tealbingy 1/28/2011 11:51:33 AM(UTC)
Removing Agitator (Washer Repair)
by dap 9/21/2010 9:00:54 AM(UTC)
removing agitator (Washer Repair)
by gregdcwirth 4/2/2010 5:52:53 AM(UTC)
Belarus rmullar 10/11/2009 2:39:52 PM(UTC)
Removing agitator (Washer Repair)
by Jeffrey M. Quirante 6/22/2008 12:33:33 PM(UTC)
by Yago 4/23/2008 3:06:04 AM(UTC)
by george m 4/1/2008 2:48:00 PM(UTC)
by bubbatippy 1/23/2008 12:04:03 PM(UTC)
